2002 Disco Low Oil Pressure
Old Aug 29, 2020 | 07:53 PM
  #21
Extinct's Avatar
I think you found it.
Old Sep 1, 2020 | 09:10 AM
  #22
Ferrarone's Avatar
Hey all,
I just completed a pressure test after reassembling the Disco, looks like it was that one bolt by the oil pickup tube. My current pressure test results are now:
Initial Startup: 46 PSI
Steady Cold Idle (750 RPM): 40 PSI
2K RPM Cold: 46 PSI
Steady Hot Idle (700 RPM): 32 PSI
2K RPM Hot: 43 PSI
Versus before:
Initial startup: 32 PSI
Steady Cold Idle (750 RPM): 6 PSI
2K RPM Cold: 16 PSI
Steady Hot Idle (700 RPM): 7 PSI
2K RPM Hot: 14 PSI
Thanks for assisting me everyone.
Old Sep 1, 2020 | 10:19 AM
  #23
Richard Gallant's Avatar
Good news and thanks for updating
Old Sep 1, 2020 | 12:16 PM
  #24
greisinb's Avatar
Awesome, glad you found it. I would have been terrified to even crank it if I had a bolt left over after reassembly!
Old Sep 3, 2020 | 06:20 PM
  #25
JackSpratt's Avatar
Banned
Originally Posted by Ferrarone
Hey all,
2K RPM Cold: 46 PSI
2K RPM Hot: 43 PSI
Versus before:
2K RPM Cold: 16 PSI
2K RPM Hot: 14 PSI
So this bolt .. when it's left out on purpose .. causes the PSI to drop creating all sorts of issues ...
You never needed new bearings ... it was only the bolt that was missing that was the cause of the low PSI ?
Old Sep 3, 2020 | 09:07 PM
  #26
Ferrarone's Avatar
I left it out by mistake, but yes. It looks like if any bolts in that area are left out or not torqued it will hinder oil pressure. It’s like sipping a soda with a cracked straw, the air bubbles come right on in. I’m lucky the issue wasn’t more severe.
Old Sep 4, 2020 | 04:42 PM
  #27
05TurboS2K's Avatar
Doesn't take much air to cause cavitation on a pressure pump. Good catch.
lrjon
Apr 12, 2015 02:37 PM
FlyingZebra34
Aug 6, 2013 12:17 AM
Bartlomiej
Jul 5, 2013 09:14 PM
MC04DII
Feb 23, 2013 09:25 AM
Spike555
ROAMING WITH FRIENDS
Mar 23, 2011 09:29 PM
