oil pressure shenanigans
Old Aug 5, 2013 | 05:48 PM
FlyingZebra34's Avatar
Default oil pressure shenanigans
Finally got the gauge on the A pillar working and will get some pics up but first I think I might have some issue.
Cold-
Idle - 51psi
2k rpm - 57psi
Warm
Idle - 27psi but occasionally drops to 23-26ish and makes strange noise (maybe oil pump is dying?)
2k rpm - 50
Old Aug 5, 2013 | 05:50 PM
Also I'm running 10w-40 Castrol conventional motor oil with Lucas oil stabilizer addative
Old Aug 5, 2013 | 07:19 PM
You may want to talk to whoever you bought the gauge from and let them know it is reading high, can it be recalibrated.
Idle pressure are around 40's cold and 10 to 12 when hot.0
Old Aug 5, 2013 | 07:29 PM
caymandrew's Avatar
Idle pressure are around 4's cold and 10 to 12 when hot.0
Really? I have almost identical readings:
Cold 45 PSI - 2k rpm 52 PSI
Hot 28 PSI - 2k rpm 52 PSI
Rotella 15w40
Old Aug 6, 2013 | 12:17 AM
idle would have to be above 7 or oil light would be lit....
At cold, the idle PSI is high because the bypass valve in filter is activated and shunting the filter media. Would be close to same value as 2500 rpm cold.
My values a year ago were :
44 PSI cold (45 F) idle or 2500 rpm
42 PSI warm (175 F) - 2500 rpm
24 PSI warm (175 F) - 700 rpm
(97 D1, but D2 spec is 50 PSI)
XxRoverAllOverxX
Off Topic
Jul 18, 2011 11:00 AM
eaglewing
Apr 16, 2011 11:06 AM
lipadj46
Oct 17, 2010 06:34 PM
tito5590805
Oct 4, 2010 09:11 AM
DooDer
Jan 12, 2010 10:46 PM
