2002 disco2 tracking down leaks
Old Feb 25, 2009 | 12:29 PM
slave600's Avatar
that is exactly where the drips of coolant are coming from (left side bell housing!), but just as discomike stated that it is most likely a head gasket, but the valley gasket would take the same amount of labor to get access too right? so it may be a moot point (the valley is the large gasket offered in the atlantic british kit right?)
- either way ill check that area for the leaking coolant...... i'm still stumped on the oil on the front, tho
Old Feb 25, 2009 | 06:18 PM
Urban Panzer's Avatar
That is my point, it is just as likely to NOT be the head gasket, the valley pan gasket can be done in a couple of hours, the headgaskets are a dif kettle of fish all together.
If you take a look where I suggested, you will see where the head gasket lies easily , and the valley pan gasket which is higher up, either way I would personally, DEF not condem the headgasket till you physically see that is where its leaking from.
I can just imagine how many V8's over the years have had headgaskets replaced for no reason because of this common leaking area, and people would be none the wiser really as the valley pan gasket has to be done during the job anyway.
Old Feb 25, 2009 | 09:53 PM
unimoged's Avatar
Urban panzer has it right on. I just added another 2004 SE to the herd to replace the 2001 SE7 and guess what, it had a major coolant leak down the left side of the bell housing like the problem that slave 600 is having.
It was exactly what urban panzer stated; the lower intake / valley pan gasket was leaking. Replaced it this past weekend and it cured the problem.
But before dismantling it, I did a compression check to make sure I had no issues with internal compression loss, the oil had no water in it, the spark plugs were all similar in appearance and there was no problem compression loss into the cooling system.
Old Feb 27, 2009 | 10:20 AM
slave600's Avatar
any chance someone can explain what the valley gasket is? is it an intake gasket or does it actually cover over a large area in the intake manifold area??? (never seen a d2 pulled apart!!). and unimoged explain again how i can view the area.... i have like an inch of room between the firewall and the left side of the engine back, how can i view the leaking area u spoke of?? from under the truck?? thanx
Old Feb 27, 2009 | 10:42 AM
jycsalas's Avatar
This is the valley pan gasket. You remove the lower intake manifold(left/top) and then there is the valley pan gasket (right/bottom)
Attached Thumbnails 2002 disco2 tracking down leaks-valley-pan-gasket1.jpg   2002 disco2 tracking down leaks-valley-pan-gasket.jpg
Old Feb 28, 2009 | 02:33 AM
Cleaning out my pc and I found some piccys from when I did My valley pan gasket on my D1.
You can clearly see the top corner (rear left corner when installed) is where it has leaked, then runs down onto the bell housing.
Spencerfitch
Sep 27, 2020 12:17 PM
FlyingZebra34
Apr 22, 2013 12:07 AM
cipher982
Jan 11, 2013 12:44 AM
collin Barrows
Jul 18, 2012 09:19 PM
glassman66
Feb 16, 2012 12:17 PM
