2002 Discovery overheat
Old Jun 1, 2008 | 08:36 PM
unstable's Avatar
Default RE: 2002 Discovery overheat
I wonder what Mike is thinking to call this a red flag issue...Any insight?
I am glad to hear that we can mostly agree that touching a radiator isn't any kind of standardized test for determining coolant problems in this vehicle. With that said I think Erubin probably had a bad t-stat.
Old Jun 1, 2008 | 09:14 PM
jkid's Avatar
If the radiator is cool, that means that no hot coolant is circulating through it. Either a clogged radiator, bad pumpor evenmaybe a blown head gasket could disrupt the circulation enough. I'venever had a reason to testmy radiator, but I'd think it would be hard to tell by feeling it, maybe with an infrared thermometer though. Seems like it would overheat though, I guess it depends on the circumstances. Nothing like making one post, disappearing and causing confusion though.
Old Jun 1, 2008 | 10:15 PM
sandroverdisco's Avatar
7th Gear
hey, are you touching it before t-stat opens? or at the end of a long drive? i would still listen to mike to avoid costly repairs.
Old Jun 9, 2008 | 11:02 AM
erubin's Avatar
I've removed the WP and it is fine. I've tested the radiator and it flows perfectly. I drive the truck 30 miles and everything is hot except the lower rad hose (under the t-stat)and the entire radiator. They are best described as cold, not even hot. T-stat was replaced but still same problem. I'm stumped.
Rando B
Jan 2, 2015 08:15 PM
moussa
Feb 8, 2010 10:24 AM
ajs1iron
Mar 8, 2007 12:22 AM
jakea4d2
Oct 26, 2006 11:10 PM
whitedisco11
Apr 27, 2006 07:42 PM
