Sponsored by: CARiD
Overheat/Coolant leak (flood) on 2001 Disco II
Old Mar 7, 2007 | 06:04 PM
ajs1iron's Avatar
Default Overheat/Coolant leak (flood) on 2001 Disco II
I just purchased a 2001 Series II Disco with 61K miles. (My first Rover)
I thought it was a good deal, but two weeks later it overheated and the coolant flooded out the bottom.
The service guy where I bought it said it was a Timing Cover Gasket and fixed it.
I am worried that it is something more major.
Any advice would be appreciated.
Thanks,
Tony in NC
Old Mar 7, 2007 | 08:31 PM
geoman's Avatar
Default RE: Overheat/Coolant leak (flood) on 2001 Disco II
Tony,
The timing case cover is a known area where coolant leaks occur. But make sure the water pump is checked out, and have someone that is knowledgeable take a look at the head gaskets to make sure they are not seeping.
regards,
Geoman
www.eurotekapg.com
Old Mar 7, 2007 | 10:14 PM
I agree, if for any reason you start running warm or have to start adding coolant, go have the coolant system pressure tested to verify where the leak is.
Mike
Old Mar 8, 2007 | 12:22 AM
tailchaser0527's Avatar
Definately have the system pressure checked it'll tell you a lot. The radiator went out in mine and they're not cheap, about $500(parts only)for mine, and i'm sure the head gaskets aren't cheap either. If the water pump is going bad, it's not a huge deal, I did my own for about $150 total.
koolkoreanked
Aug 14, 2013 11:08 AM
Vantablian
Jul 8, 2013 10:53 AM
leddifer
Oct 27, 2010 06:33 PM
timdunbar
Sep 30, 2010 05:08 PM
disco524
Aug 1, 2010 02:11 AM
