2002 land rover discovery
Old Oct 31, 2012 | 01:44 PM
dmczar0028's Avatar
5th Gear
Angry 2002 land rover discovery
I have had my truck sitting outside for about 15 months been having trouble with it overheating.. i recently decided to put it in the garage when turning it on i realized that i could not accelerate but when i tried to reverse the front tire seemed to drag along... on the dash i see the decline picture shown and the blinking of M AND S...
PLEASE ADVISE I CANT AFFORD TAKING IT TO THE SHOP...
Old Oct 31, 2012 | 02:07 PM
First, take your battery out and have it tested and fully charged , reinstall and see what happens.
Old Oct 31, 2012 | 02:27 PM
dmczar0028's Avatar
5th Gear
thanks...with a car siiting that long what maintance should i do asap
Old Oct 31, 2012 | 02:44 PM
AwannaD2's Avatar
Default Def your battery
My batt went downhill almost overnight. I jumped it and got the flashing M and S. Basically a safety function of the trans ecu when the voltage is too low. I let mine run for about 10 min, shut it off and immediately restarted it and it was gone. Drove it home, tested the batt and replaced it.
Old Oct 31, 2012 | 02:47 PM
dmczar0028's Avatar
5th Gear
Ok ill try that but im confused in why the front tires would be locked i was thinking it could be the rust over the time sitting their in chicago weater or the differantal lock
Old Oct 31, 2012 | 03:45 PM
lr2001silver's Avatar
Banned
Things can seize up over time, how ever Mike makes a very good point about your battery issue with the m & s lights. Now for the other part you need to inspect all drive line components and grease everything and then start working it slowly to get grease coating things up then re grease and go from there. Remember that all the fluids will settle over time that's part of the reason why its bad for vehicles to sit for extended periods of time.
Old Nov 1, 2012 | 07:59 AM
drowssap's Avatar
possibly a frozen caliper from sitting
shoplacoss
Jan 8, 2010 10:36 PM
Street Wolf
13
Apr 21, 2009 03:04 PM
northshorelandrover
Dec 14, 2008 05:05 PM
RoverInChatt
Dec 10, 2008 01:40 PM
dmcmurtrie
Dec 8, 2007 03:46 PM
