2002 LR Disco 2 SE
Old Sep 1, 2017 | 12:12 PM
Laura Moore's Avatar
3rd Gear
Default 2002 LR Disco 2 SE
P0130 & P0150
Changed all four o2 sensors, in addition to SAI solenoid valve, purge valve and air duct tubing and still get codes for P0130 & P0150!!!!!
I am about to change front sensors again!!! Help!!!
Old Sep 1, 2017 | 02:09 PM
04in719's Avatar
Did you reset the codes after replacement of those components and the codes came back up???
I had a similar issue and it turned out I had a wire on the harness side for one of my O2 sensors that had melted and was grounding out.
Old Sep 1, 2017 | 04:13 PM
3rd Gear
Smile 2002 LR Disco 2 SE o2 sensor
I did reset codes and so did the LR mechanic. I will check wiring.
Thank you
ANAN
May 6, 2007 01:31 PM
m4guru
Dec 1, 2005 12:23 PM
ANAN
Jul 1, 2005 06:11 PM
Robbo
Jun 15, 2005 05:03 AM
GNXtoWS6
Feb 28, 2005 04:01 AM
