2002 LR Disco 2 SE
P0130 & P0150
Changed all four o2 sensors, in addition to SAI solenoid valve, purge valve and air duct tubing and still get codes for P0130 & P0150!!!!!
I am about to change front sensors again!!! Help!!!
Did you reset the codes after replacement of those components and the codes came back up???
I had a similar issue and it turned out I had a wire on the harness side for one of my O2 sensors that had melted and was grounding out.
