2003/4 Handbrake Cable Adjustment. Every forum gets it wrong.
Old Sep 9, 2018 | 04:10 AM
OffroadFrance's Avatar
Default 2003/4 Handbrake Cable Adjustment. Every forum gets it wrong.
For the handbrake cable adjustment on a D2 2003/4 it is done from underneath in the transmission tunnel. You will need a crows foot spanner and also a long extension and also a large crows foot spanner with a long extension. Undo the top larger nut half a turn then unscrew the lower sleeve nut until the handbrake is fully on at 3 clicks of the ratchet and then holding the lower sleeved nut from turning tighten the larger upper nut. Ensure the drum brake is correctly adjusted first or it's an abortive exercise. Job done.
The 1998 to 2002 cable adjustments are shown in RAVE.
Old Sep 25, 2022 | 03:26 PM
fma01709's Avatar
Thank you this clarifies it. What might have caused the handbrake to come loose? Mine is totally loose and the cable seems not broken.
OffroadFrance
Jun 16, 2021 02:58 PM
philwarner
Mar 30, 2017 11:16 AM
stb616
Dec 3, 2014 02:03 PM
ColoDisco
Jul 26, 2011 06:28 PM
coops
Jul 1, 2007 08:11 AM
