D2 Mechanic Services Denver area
Old Sep 25, 2022 | 07:08 PM
RA122125's Avatar
Banned
Default D2 Mechanic Services Denver area
Can I ask if there is an appropriate place to advertise Mechanic services for these D2's, for the Denver Colorado area?
I have noticed that there is a really long wait list for most of the LR shops in here, and their prices are really high (like $225hr.). I'm an old ASE certified mechanic, and have been rebuilding my own D2 in my garage for the last year or so. I won't say I know everything about them, but I would say that my work is on par with, or better than, most I'm seeing coming out of these shops. I also do have a Nanocom, and I know how to use it, lol.
If it's alright with the forums, I'd say go ahead and PM me here with what you need fixed, and I'll message you back quickly to let you know if I can help
So far I've successfully done:
Head gaskets with studs
Coil packs, spark plugs and wires
Upper and lower intake
Valve cover gaskets
PCV mod
Crank Position sensor (CPS) replacement with heat shield upgrade
Brake booster Intake vacuum attachment replacement
Brake Master cylinder replacement and Stainless brake lines (6 piece kit)
3 Amigos plan "B" mod, Slabs system diag and brake bleeding
Timing cover. oil pump and timing chain/sprockets, with Harmonic balancer speedi sleev'd
Oil pan and cruciform seals
Electric fan and cooling system modification, including inline thermostat, all new hoses coolant reservoir
A/C cooling fan mod/replacement
Tensioner and Idler pulleys with new Belt
Key and remote replacement/reprogramming, and BCU programming for all options
Rear tire carrier mod and flip
Headliner replacement, roof sound deadening, sunroof sealing and roof rack replacement ('04 to '03 extended rails)
HVAC Blower fan replacement
LED conversion on all ext lights
Window regulator replacement
Radio replacement with Android car stereo 11" screen, and front/rear cameras
SRS light diag and repair
"Cold air" intake mod
All fluids flushed/changed including Transmission, Diffs, Brakes, Coolant, power steering
Front Pinion seal replacement and front driveshaft
Rear differential replacement
All new Koni Shocks and steer stabilizer
Etc...pretty sure I'm forgetting a few things
My next projects are going to be ball joints, axle seals, CV boots, brake pads/rotors, bumpers and sliders, etc...
Stephen Perez
Mar 15, 2020 09:23 PM
TopCat
Aug 19, 2014 01:05 PM
discobob
Jun 10, 2014 06:38 PM
JBEGIN
Dec 10, 2008 05:37 PM
MadBilly
Jan 16, 2006 04:33 AM
