2003 CDL Install
Old Jun 27, 2024 | 08:27 PM
Sgsowen's Avatar
Default Update
Originally Posted by Oasisplayer311
So it looks like my 2003 (Manufactured in 2002) has the wiring ziptied off to the side of the transmission. Instead of rewiring a light in, I was able to talk to Eric at Lucky 8 about some of the wiring assemblies. These were the two parts needed to plug into the ECU
CDL Wire Assembly:
Part #YMQ105170
CDL Switch
Part #IGM500011
I will keep you posted when it gets installed!
Know this was some time ago… did this work? Looking at putting CDL in my 2003 discovery and wondering how the wiring to show it on the dash is done.
Thanks
Old Jun 27, 2024 | 09:24 PM
Harvlr's Avatar
Someone with more experience than me will pipe in, but I think the wiring is already there.
Old Jun 28, 2024 | 08:48 AM
mollusc's Avatar
The wiring is there, but you do have to cut into the harness near the shift lever and connect to ground. This is all pretty well documented.
Old Jun 29, 2024 | 08:34 AM
XRAD's Avatar
maybe something here you can use:
https://landroverforums.com/forum/di...15/#post732360
Old Jun 30, 2024 | 09:13 AM
mollusc's Avatar
Originally Posted by XRAD
Not really anything useful there about this question if the switches are functional. It does seem that maybe some 2003 D2's don't have the wiring, so that would be the first thing to check. If the wiring is there (amending my previous statement) then getting the dash light to work is pretty simple.
Old Jun 30, 2024 | 11:49 AM
acg's Avatar
acg
Thanks
Sgsowen,
You need to be more specific. Are you swapping to a pre-2004 or 2004 transfer case? The diff lock sensors are different styles for both. Here is more info:
https://landroverforums.com/forum/di...1-86397/page2/
The two types of sensors:
- Pre-2004 transfer case (p/n PRC2911): https://www.roverparts.com/electrica...noids/PRC2911/
- 2004 transfer case (p/n IGM500011): https://rimmerbros.com/Item--i-IGM500011
Old Jul 1, 2024 | 07:25 PM
jethron's Avatar
@Sgsowen I did that job recently. This video was pretty helpful to visualize how its done. Relevant part is about 13 minutes in.
rikkd
Sep 29, 2021 04:24 PM
LRD2Dave
Dec 3, 2020 01:55 PM
Mullins.cody
Aug 21, 2020 02:45 PM
crainb45
Jun 7, 2009 05:38 PM
Willie 00D2
Sep 11, 2008 02:05 AM
