2003 D2 Engine failure
Old Jun 7, 2020 | 01:16 PM
zski128's Avatar
Default 2003 D2 Engine failure
I picked up a 2003 parts truck a couple
months back and just got around to tearing down the engine. The previous owner said it blew a head gasket as it lost coolant and white smoke out of the tail pipe. As I tore it down I noticed the exhaust ports on the two center cylinders on the passenger side where steam cleaned. Not a good sign. Anyway take a look at the pictures below. My guess is that the liner slipped low enough for the top piston ring to pop out and destroy it. It must have been loose for some time as the cylinder head has quite a groove hammered into it.
I guess this block will make a good end table
Old Jun 7, 2020 | 01:19 PM
Saturnine's Avatar
Good lawdy
Old Jun 7, 2020 | 01:25 PM
XRAD's Avatar
rut row.... block is , but maybe the crank is still good....
I don't know if a slipped liner definitely indicates a poor casting/water ingress to liner....maybe it can still be T hatted w/new sleeves.....
Old Jun 7, 2020 | 01:26 PM
cvhyatt's Avatar
Reminds me of my original purchase! My condolences. I got a good bare block from roverlandparts.com
Old Jun 7, 2020 | 02:22 PM
zski128's Avatar
This was just a parts truck so was pulling everything off of it. A spare block would have been nice, oh well. Interestingly this was the same cylinder that failed on my old 2004.
Old Jun 7, 2020 | 05:37 PM
Extinct's Avatar
That is quite interesting, the lower end of the block is supposed to support the liner.
Old Jun 7, 2020 | 06:59 PM
zski128's Avatar
Great point. I had the sump off to get the torque converter bolts out but didn’t notice any metal fragments. The engine also bars over as normal, I’ll take a look at the underside of the block soon.
Old Jun 7, 2020 | 11:42 PM
Richard Gallant's Avatar
wow how long did they run it like that I wonder
Old Jun 8, 2020 | 02:18 AM
The Deputy's Avatar
At least it's nice to find the "smoking gun". No doubts about the condition of that block.
Old Jun 13, 2020 | 06:24 AM
zski128's Avatar
Some follow up pictures as I finished stripping the block. The crank and the rod on the damaged cylinder does not look bent to the eye but will have to measure. This engine had 135k on it.
Engine had lots of oil leaks between the transmission but the rear main seal and crucifix seal was dry
The oil leaks where from the oil pan gasket in the rear and one of the oil gallery plugs.
There was a lip to hold the sleeve in place...
This is what the lip should look like, flush with the sleeve.
keninnc
Feb 7, 2020 06:03 PM
03_Rover
Aug 29, 2019 07:34 PM
Gonow
Build Threads
13
Mar 1, 2019 10:51 AM
Randy Murzyn
Feb 14, 2018 01:56 AM
jfall
Mar 24, 2014 03:05 PM
