2003 D2 radio in "Wait" mode for nearly a year
Old Aug 31, 2017 | 08:15 AM
bcolins's Avatar
Default 2003 D2 radio in "Wait" mode for nearly a year
My radio has been in the WAIT mode for nearly a year since shortly after buying it. It was in Wait on the day I bought it,....then after driving it a bit it changed to the mode where I could enter my code. But, the code included a Zero,.....and there is no Zeros on the buttons,....the Local LR dealer was unable to tell me how to enter the code,....I had a few suggestions from the forum, tried them,....after the 3rd or 4th attempt, it permanently went into WAIT mode and it has been holding WAIT since last November. Granted the truck was mostly parked until June of this year, when I began driving it with more regularity,....guessing I have put a couple hundred miles on it since I started driving it more regularly
any suggestions?
BC
Old Aug 31, 2017 | 08:29 AM
The Deputy's Avatar
You've been very, very patient...
Try disconnecting your battery for a few minutes, every time I disconnect the battery on our 03...the radio "asks" to have the code entered (which was written down in our owners manual).
Good luck, Brian.
Old Aug 31, 2017 | 01:44 PM
Chrisw7562's Avatar
Which deck do you have? Radio only? Cassette deck? Nav system?
Old Jul 10, 2018 | 06:37 AM
bcolins's Avatar
Chris, I'm just now seeing this and the problem is still ongoing. for nearly 2 years now. I don't have Nav,....not sure if I have a cassette or not. Ill have to check it.
Old Jul 10, 2018 | 07:23 AM
Chrisw7562's Avatar
Well your options are pretty wide open. Since you don't have the nav features the wiring is pretty simple. You can easily search the forum for the exact adapter you will need and it's sold on Amazon and places like Crutchfield.
If you are just looking for something inexpensive you can always find a deal at Walmart on something that will just drop in and replace the factory radio easy enough. The mechanics of swapping one out are simple, especially without the nav system.
Old Jul 10, 2018 | 07:31 AM
bcolins's Avatar
Oh, I hadn't even considered just replacing the unit. Maybe be time to give that some thought, but, I actually would prefer to just get this unit working. There has got to be a fix for this "Wait" mode.
Old Jul 10, 2018 | 07:38 AM
Chrisw7562's Avatar
Persistence! I like it!!
But after two years I'd have thrown in a new one. Ton of selection for under $50 at Walmart!
Good luck with the search.
Old Jul 10, 2018 | 08:24 AM
mln01's Avatar
Or even replace the factory radio with another factory radio. Complete plug and play, as long as you get the same version. They are plentiful and dirt cheap.
hh65flyer
Feb 15, 2024 04:19 PM
Dr_Who
May 19, 2009 10:58 AM
b c
Jul 30, 2008 09:03 PM
roverallover
May 27, 2007 03:09 AM
jmang
Dec 11, 2006 01:51 PM
