2003 Disco II 60K miles running rich HELP
Old Feb 15, 2013 | 11:48 AM
pvflyer's Avatar
Default 2003 Disco II 60K miles running rich HELP
I've a 2003 Disco II , it just turn 60K miles runs great no issues. But every time I am stop in traffic I can smell it running rich. Could it be the Oxygen sensor or the catalytic converter or maybe something else?
Any help would be welcome.
Old Feb 15, 2013 | 11:52 AM
bballjames's Avatar
Is the check engine light on? Are there any codes?
clanch's Avatar
Check engine light on?
Old Feb 15, 2013 | 11:55 AM
You may have some stored codes that would narrow the chase down, any check engine light on?
Could be O2 sensors (they tell ECU how to adjust fuel rich or lean), but they usually makes codes. Since this happens at idle, the idle air control valve could be involved can be cleaned with carb cleaner spray, remove, spray, but don't move the tip by hand). The mass air flow sensor if dirty can make the engine computer use bad data for adjusting fuel mix. MAF can be cleaned with a special cleaner made just for it, but only when stone cold.
If you don't have a code reader many auto parts stores will read for free, write down the number of the code and search that or post it back here.
Old Feb 15, 2013 | 12:19 PM
pvflyer's Avatar
Thanks guys. Yes engine light is on I've got to do the 60K tune-up. I've the ABS amigo, would it help with any other code besides brakes and TC related issues?
Old Feb 15, 2013 | 12:56 PM
agthird's Avatar
need the codes dude......
Old Feb 15, 2013 | 01:19 PM
bballjames's Avatar
Nope. Don't think so. You can go to most any auto parts chain and they will read the codes for you.
Old Feb 15, 2013 | 01:23 PM
pvflyer's Avatar
Thank you all. Will get the codes.
Old Mar 26, 2013 | 04:22 PM
pvflyer's Avatar
I've got code P 1000 is that O2 sensor Up or downstream. Anybody?
Or should I go ahead and replace both?
Thanks
Old Mar 26, 2013 | 04:30 PM
willrok13's Avatar
Thanks
P1000? Where did you get the codes read? Or more importantly, cleared?
Regardless, it's likely the upstream (closest to engine) as the downstream likely is fine at your mileage.
