2003 Disco II 60K miles running rich HELP
Old Mar 26, 2013 | 04:31 PM
When was it last tuned along with new 8 mm silicone wires, what octane gas are you running?
Are you sure the fault code number is a P1000, can't find it listed on any of the normal Rover code sheets.
Old Mar 26, 2013 | 04:35 PM
willrok13's Avatar
Yeah, I looked it up and P1000 is apparently a default for when the codes are cleared but the self diagnostic checks have not completely cycled.
Old Mar 26, 2013 | 04:57 PM
pvflyer's Avatar
Originally Posted by willrok13
P1000? Where did you get the codes read? Or more importantly, cleared?
Regardless, it's likely the upstream (closest to engine) as the downstream likely is fine at your mileage.
Drove down my local Pep Boys store. And had my engine diagnosed. And that's the code they gave me ( P 1000 O2 sensor 10). I think the guy told me upstream. However I had my 3 years old and 7 years old with me @ the the time and it was a bit chaotic.
But I think Ur right about upstream.
Thanks
Old Mar 26, 2013 | 05:15 PM
pvflyer's Avatar
Gas Shell 92 or 89 octane mostly 92. wires and serpentine about 20k miles ago. Engine runs great no stalling a little vib on idling but it runs rich. Car is in very good working condition everything works no majors. 60k tune up its past due.
CODE P1000 o2 sensor 10 that's the only 1 I've got
Thanks
Old Mar 26, 2013 | 08:45 PM
jfall's Avatar
P1000 is not a valid landrover code
Just buy a code scanner or an Ultra Gauge.
If you need codes figured out - this site may help
http://enginecodemaster.com
Most scanners decode the code for you. But the above site will tell if a code is valid or not.
Most of the Rover specific codes are in that site.
5-0 disco
Aug 16, 2013 02:06 AM
vpadferg
Jan 19, 2013 09:41 PM
ADDAM
May 17, 2012 11:21 PM
jake0258
Jan 15, 2012 11:57 PM
pit_ownr
Nov 17, 2008 12:24 AM
