2003 Disco Overheating
Old Sep 11, 2009 | 07:28 PM
jwood700's Avatar
Default 2003 Disco Overheating
When the truck is idling for a while it starts to over heat. I check the coolant it is fine so here is what I do know: The radiator has not been flushed the truck has 80K Miles on it. The serpentine belt needs to be change very badly. The fan clutch after running for a while I can spin it easily. I assume it is most likely the clutch thought I would confirm with you guys to see if you all agree.
Thanks,
J
Old Sep 11, 2009 | 07:55 PM
Replace the belt and fan clutch and you should be good to go.
Old Sep 11, 2009 | 08:16 PM
Have you been having to add coolant, is your level low?
Is the electric fan on the front of your truck coming on when driving in town and or when the a/c is on?
aguison
May 29, 2014 08:49 AM
SiracHaile
Sep 15, 2013 08:43 AM
sickws6
Aug 1, 2013 09:48 PM
bluescorpion
Sep 24, 2012 03:44 PM
2003LANDROVERDISCOVERYRED
Feb 28, 2011 10:21 AM
