2003 Disco with P0171, P0130, and P1171
Old Feb 6, 2014 | 07:32 PM
marshman442's Avatar
ok, i figured that. I Ordered a front O2 sensor. Is Bank 1 the driver side or passenger side?
Old Feb 8, 2014 | 09:05 PM
Charlie_V's Avatar
Bank 1 is the bank with the number 1 cylinder. That's driver side on yours.
Old Apr 23, 2014 | 08:31 AM
Well, I changes the Bank 1, Sensor 1 O2 Sensor and the MAF about a week ago and the codes went away. Today the truck was idling rough when I would stop at a traffic light. Now I've got some new codes and a few of the same. Any thoughts as to what to do next?
Codes are as follows in the order they appear:
1. P0171 - system too lean Bank 1
2. P1174 - Lambda control adaption fault bank Last occurrence maximum signal
3. P1171 - system too lean Bank 1 Sensor 1
4. Po130 - Bank 1 sensor 1
Once I cleared those codes within about 2-3 minutes I got the following code:
P0130 - bank 1, sensor 1.
Please Help!
Old Apr 24, 2014 | 05:22 AM
any suggestions what to check next?
Old Apr 24, 2014 | 06:03 AM
drowssap's Avatar
possibly a vacuum leak?
Old May 23, 2014 | 11:19 PM
I suspected that. The O2 sensors are working properly (switching voltage .9 to .1) however the short term / long term fuel trim are up around 25. I suspect I am getting "un-metered" air into the system somewhere.
Going back to my original suspicion, is there a way to check the evap valve? Is this valve normally open or closed?
Old Jun 2, 2014 | 09:05 PM
Jgkcobra's Avatar
I have a p0171 too lean bank 1 also, we're you able to find out what the cause was. I had new o2 sensors n cat converters put in n this code shows up
Old Jun 2, 2014 | 10:03 PM
I just got done building a smoke machine to perform a smoke test on the system. I will keep you posted as to my finds.
If anyone is interested in an inexpensive way to test for vac leaks, here is a good source.
Old Jun 3, 2014 | 12:27 AM
dusty1's Avatar
what is a keyanne?
Old Aug 9, 2014 | 10:44 AM
OK, here it the update on the finds of the P0171 code cure.
I performed a smoke test and found a bunch of smoke pouring out from what appeared to be my intake valley pan gasket. So before I pulled the lower portion of my intake I decided to check the lower half of the intke with the smoker by making a special adaptor plate by using the upper intake gasket as a template. (see photo)
This revealed that I had multiple o-ring leaks at my fuel injectors. The cure was a rebuild kit I found on e-bay (Mr. Injector).
So I put it all back together and whoola, no more codes and it runs like a champ!
http://s464.photobucket.com/user/mar...hoto.jpg.html]Name:  photo.jpg
cornbreadj
Feb 18, 2014 02:06 PM
IndianJoe
Dec 4, 2012 05:13 PM
disco chelsea
Aug 9, 2011 09:58 PM
nynole
Jan 26, 2008 06:02 PM
