2003 Disco SE Manual Tranny
Old Jun 8, 2020 | 01:21 AM
Re1chers's Avatar
4th Gear
Default 2003 Disco SE Manual Tranny
Hi all. New member here. I'm not too knowledgable on these vehicles, looking for advice before buying. Thinking of purchasing a 2003 Disco SE. It has stock automatic transmission and I'd like manual transmission. Anyone swapped a manual transmission into this make? Is it possible? Affordable? Manageable? Thanks.
Old Jun 8, 2020 | 06:18 AM
mollusc's Avatar
https://landroverforums.com/forum/di...al-swap-79203/
Old Jun 8, 2020 | 10:15 AM
Richard Gallant's Avatar
After reading the threat @mollusc posted, that is going to be a ton of work, and a parts it is not a simple swap. I would suggest you stick with the automatic and get everything else sorted out, then switch if you want.
The only manual I found for sale was 2200 US, and you still need to buy additional parts.
Old Jun 8, 2020 | 10:36 AM
XRAD's Avatar
Nice build...shows all the detail...but he did not install a locking t-case?
Old Jun 8, 2020 | 10:52 AM
@XRAD he had an 04 so it should have already had the locking T-case
Old Jun 8, 2020 | 11:46 AM
Re1chers's Avatar
4th Gear
I found Conrad's thread almost immediately after posting last night.... looks like a beast of a project. Definitely satisfying once all is said and done. I'll probably just stick to the auto tranny.
Old Jun 8, 2020 | 12:54 PM
mollusc's Avatar
He also references the shift lock ability in some of the later posts, and you can see that the t-case lever has the lock symbols on top of it.
Old Jun 8, 2020 | 07:55 PM
XRAD's Avatar
You know what , I missed that. I just saw the pic of his tunnel cover and it was not slotted for locking shifter... guess he opened it up later
patsilva
Jan 3, 2012 02:07 AM
Dahne23
Feb 25, 2008 11:51 AM
rpg123
Dec 8, 2007 01:24 AM
usmc_grunt
Nov 22, 2006 11:46 AM
missoulanancie
Mar 7, 2006 11:28 PM
