2003 Disco, Smoke, Syrup Smell and Badly Leaking!
Old Aug 31, 2009 | 03:39 PM
Skibum232's Avatar
Originally Posted by hilltoppersx
download the RAVE manual. it will answer all your questions like where is this and what type of fluid does this take. http://www.landroverresource.com/
Thanks so much,
Mike I had my wife check and the coolant tank is empty, fluid is pink.
I'm having them tow it to a repair shop I've used in the past on my jeep. If something sounds amiss I have a shop a buddy uses on his Disco and Range in Denver I'll send it to.
Old Aug 31, 2009 | 05:20 PM
Let us know what they find and what the estimate so you will know if they are not over charging you.
Old Aug 31, 2009 | 06:34 PM
Skibum232's Avatar
I will know in about 24 hours and will post the diagnosis and price and hopefully they are on the up and up.
Again thanks for all the help.
Old Aug 31, 2009 | 10:52 PM
oysterhead's Avatar
keep fingers crossed for busted hose as opposed to head gaskets
Old Sep 1, 2009 | 01:44 PM
ColoDisco's Avatar
In the future there is always my shop. I am a long time vw/audi tech with a rover myself. I can fix pretty much anything. You can reach me here or at http://www.vppperformance.com
Old Sep 2, 2009 | 12:31 PM
Skibum232's Avatar
Updated, Disco is at the shop.
They ran a coolant pressure test and the throttle body heater was leaking. Part is $30 and labor is $200.
Shop also recommended replacing two inlet hoses around the throttle body heater for $60 and labor is $300.
Seems on the up and up but I'm not sure about the additional hoses?
So glad it wasn't a head gasket, misfire or about 3 other nightmare scenarios I had running through my head.
Old Sep 2, 2009 | 12:33 PM
98roverguy's Avatar
OMG. Do that simple work yourself and save $500. They are ripping you off!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 2, 2009 | 12:42 PM
Suede's Avatar
Hell yeah they're ripping him off. $500 labor on the throttle body heater & hoses??? That's insane. A 9 year old girl could do it. RUN AWAY FAST man. Give them $100 for their time and diagnosis and then get the hell out of there. You're getting raped with no lube on this one...
Edit: Seriously man. Changing the throttle body heater plate will take you 15-20 minutes your first time. If you can screw in a new light bulb, you can change it. Please don't let them take advantage of you like this. Times are tough and they sized you up as someone they could convince to waste the money. This isn't even a case of a high price. This is pure unadulterated insanity on their part. Don't let them take advantage of you this way.
Old Sep 2, 2009 | 12:50 PM
Skibum232's Avatar
That is what I was thinking but I honestly don't have the space to do the work and time right now, I knew taking it into a shop meant paying for the service. I'm definitely bent over on this one but should I have them do all three or just the failed throttle body heater?
Old Sep 2, 2009 | 12:52 PM
98roverguy's Avatar
Skibum, I would consider ColoDiscos offer. He'll have his reputation on the line and I'm sure he would give you a far more reasonable offer. If not I could just as easily drive up there with my tools and do that job with you, for wayyyyy less. I have already done this job on my D1, and once I reviewed the rave I'm sure the job would be very similar on a 2003. We could knock that out in a couple hours I'm sure.
