2003 Disco Valve Cover Leaking
Old Sep 27, 2007 | 05:23 PM
DeepBlueWater's Avatar
Default 2003 Disco Valve Cover Leaking
My 2003 Disco ran perfectly before I let LAND ROVER VENTURA, CA service it.
They insisted on replaced myseemingly good (not leaking) valve cover gaskets - nowboth valve covers vomit oil. I'm loosing about 1/2 qt. per week.They quoted me $300 and then charged me $1,600 for the routine service and want another $799 to re-fix the issue they created.
Does anyone have exprience replacing the VC gasketson a 2003 Disco?
I've read in others posts that the intake manifold on some Disco's don't need to be removed- simply loosened to access V-covers. I this true on the 2003?
Also looking for info on the socket size and torque? Looks like a 12pt 1/4" drive?
Any help would be greatly appreciated...
Dont ever let Land Rover Ventura, CA work on your car!!!! Horrable mechanical standards / customer service.
MWmG
Old Sep 27, 2007 | 05:49 PM
Default RE: 2003 Disco Valve Cover Leaking
You might ought to call me so I can walk you out of your issues.
303-862-7680
Colorado between 7 am and 8 pm.
Old Sep 27, 2007 | 07:22 PM
jwfuller's Avatar
Holy crap! 1600 dollars???? I'm changing mine out this weekend, I'll let you know if it is a 1600 dollar job!
I have a 2003, and really it doesn't seem like it should have been that expensive at all. Removing the Intake manifold is not a big deal, and swapping the valve covers is not a major job either. Did you have any other work done besides those gaskets? DiscoMike will talk you through the repair stuff. I definitely would not go to those guys again.
Good Luck
rally1
Feb 22, 2022 06:22 AM
er1c
May 18, 2015 08:33 PM
Disco Ed
Feb 2, 2011 04:04 PM
TinSoldier
Dec 30, 2010 09:11 AM
humroot
Aug 13, 2009 07:38 AM
