2003 disco won’t turn over after rod bearings and gasket replacement
I bought a 2003 disco last year that was in rough shape. I recently replaced rod bearings and the head gaskets. When I was trying to do first start up procedures to get oil through the engine, I took out the fuel relay and tried to start it but the starter couldn’t crank the engine. Starter smoked a little also. Trying to figure out what to do
2003 Land Rover discovery SE
blue 133000 miles
blue 133000 miles
Banzai Jimmy (07-13-2020)
I hate to say it you will have to pull the pan, before after bottom end you should try turning everything with a 3/4 ratchet - plugs out. If have any significant resistance you need to recheck everything. I have seen folk do the turn after each con rod bearing and after the mains depending on how you did it
XRAD (07-11-2020)
In the future definitely rotate the engine after torquing each rod cap. Plastigauge is a pretty good idea, too, but won't show things like a rod that's out of round which will sometimes only show after replacing bearings. I've got a motor in my building with that issue right now. Ran fine till I replaced the bearings. Tried two different sets, and a different crank. Same three rods make it lock up when torqued down. They're out of round.
Not saying that is your issue, but it's possible. Pull the caps back off, then start to torque them back on one at a time, spinning between each.
Also, just double checking, you did make sure to get the caps back on the rods they came off of yes? They are match sets and can not be mixed up.
XRAD (07-11-2020)
RGC84
07-06-2020 02:34 PM
snowkistdynasty
10-25-2013 06:47 PM
Jordan Campbell
03-26-2013 09:02 AM
sarahgibbons5
09-12-2009 09:36 PM
