2003 disco won’t turn over after rod bearings and gasket replacement
Old Jul 10, 2020 | 11:05 PM
RGC84's Avatar
8th Gear
Default 2003 disco won’t turn over after rod bearings and gasket replacement
I bought a 2003 disco last year that was in rough shape. I recently replaced rod bearings and the head gaskets. When I was trying to do first start up procedures to get oil through the engine, I took out the fuel relay and tried to start it but the starter couldn’t crank the engine. Starter smoked a little also. Trying to figure out what to do
2003 Land Rover discovery SE
blue 133000 miles
Old Jul 11, 2020 | 06:48 AM
mollusc's Avatar
Can you turn the engine using a breaker bar on the crankshaft pulley?
Old Jul 11, 2020 | 08:01 AM
RGC84's Avatar
8th Gear
no, I tried but won’t turn took spark plugs out and everything.
Old Jul 11, 2020 | 12:18 PM
piperff's Avatar
possible rod cap reversed, if so more problems may have been created with rod or bearing...
Old Jul 11, 2020 | 02:01 PM
Richard Gallant's Avatar
I hate to say it you will have to pull the pan, before after bottom end you should try turning everything with a 3/4 ratchet - plugs out. If have any significant resistance you need to recheck everything. I have seen folk do the turn after each con rod bearing and after the mains depending on how you did it
Old Jul 11, 2020 | 04:45 PM
Extinct's Avatar
Yeah, likely a rod bearing half slipped down before you could tighten the bolts. Not fatal, but you will have to find the bad one.
Old Jul 11, 2020 | 05:13 PM
Alex_M's Avatar
In the future definitely rotate the engine after torquing each rod cap. Plastigauge is a pretty good idea, too, but won't show things like a rod that's out of round which will sometimes only show after replacing bearings. I've got a motor in my building with that issue right now. Ran fine till I replaced the bearings. Tried two different sets, and a different crank. Same three rods make it lock up when torqued down. They're out of round.
Not saying that is your issue, but it's possible. Pull the caps back off, then start to torque them back on one at a time, spinning between each.
Also, just double checking, you did make sure to get the caps back on the rods they came off of yes? They are match sets and can not be mixed up.
Old Jul 11, 2020 | 07:21 PM
The Deputy's Avatar
Did you remember the spacer that goes on the oil pickup tube bracket? If you forget to install spacer, lobes of crank hit tube. Yes, always rotate assembly before installing pan. Actually, rotate assenbly after each step...that way you know where you went wrong.
Old Jul 15, 2020 | 12:44 PM
Billfromthehill's Avatar
Perhaps you purchased oversized bearings by accident and are now squeezing the crank journals too much to move.
RGC84
Jul 6, 2020 02:34 PM
03_Rover
Aug 29, 2019 07:34 PM
snowkistdynasty
Oct 25, 2013 06:47 PM
Jordan Campbell
Mar 26, 2013 09:02 AM
sarahgibbons5
Sep 12, 2009 09:36 PM
