2003 Discovery 2 Foxwell code reader codes
Old May 5, 2021 | 08:23 PM
Bear774's Avatar
4wd High
Default 2003 Discovery 2 Bringing back to life after 2 years sitting
Recently acquired disco 2 2003. Sat for 2 plus years. Had the 3 amigos but was able to clear those with the foxwell nt510 elite. Still have the service engine soon light on with the following codes from the foxwell
55
58
62
60
16
73
70
will follow up with pictures and we all love pict
ures
Old May 7, 2021 | 09:02 AM
Sandman614's Avatar
What kind of codes are those? Certainly not OBD codes with that notation,
https://www.troublecodes.net/landrovercodes/
Old May 8, 2021 | 07:38 AM
JUKE179r's Avatar
The LR fault codes normally have a P and 4 digit number after it.
Old May 8, 2021 | 07:31 PM
Bear774's Avatar
4wd High
Thanks for the replies. These are the faults associated with the codes I’m getting from the foxwell. This is when I read them from the Land Rover screen. I will pull the obd2 codes when I get back to the house.
55 DTC secondary air valve power stage fault
58 DTC DMTL heater power stage
62 DTC canister purge valve fault (power stage)
60 DTC Purge canister vent / DMTL power stage fault
16 DTC Leakage detection module motor power stage error
73 DTC Mass air flow sensor fault
70 DTC Camshaft sensor fault / valve timing error.
I will post the obd2 codes soon
obd2 codes
P1 451
P0 414
P1 482
P0 454
P0 484
P0 102
P0 340
P0 134
P0 154
P0 135
P0 155
P0 141
P0 161
P0 159
I see what all the codes described, O2 sensor. Mass airflow etc. I guess I’m looking for advice as to where to begin with so many codes, some related some not.
thanks in advance again
Old May 9, 2021 | 11:15 PM
Sandman614's Avatar
obd2 codes
P1 451
P0 414
P1 482
P0 454
P0 484
P0 102
P0 340
P0 134
P0 154
P0 135
P0 155
P0 141
P0 161
P0 159
So the Scanner has it's own set of codes, that's annoying.. I would start with clearing the codes and going for a couple drive cycles, and focus on the OBD P#### Land Rover codes. Also make sure the battery is fully charged, In my experience a low battery can cause all kinds of incoherent codes and nonsense to popup.
Old May 9, 2021 | 11:48 PM
JUKE179r's Avatar
+1 for ensuring you have a fully charged battery with tight and non corroded battery terminal connections.
Old May 10, 2021 | 12:59 AM
Richard Gallant's Avatar
buy the Land Rover codes for that reader
Old May 10, 2021 | 06:48 PM
Bear774's Avatar
4wd High
Thanks so much for the reply’s. The foxwell N510 was the scanner I found that does the Land Rover “apparently it also does Jag”. I have cleared the codes, when I clear them using the scanner as a obd2 reader the service engine light turns off until the vehicle is started and the codes return. Always the same codes. When I bought the vehicle it had a dead battery so it now has a brand new battery and the terminals are clean. Although I will take a wire brush and make sure the connection is perfect.
Old May 10, 2021 | 06:56 PM
Bear774's Avatar
4wd High
Now that I look at the picture I posted the positive terminal looks like a disaster. I’m pulling it off now and will inspect and clean. I’ll post pictures and results once that’s done
Old May 10, 2021 | 11:28 PM
JUKE179r's Avatar
Yeah I see it too. It also looks like the positive cables aren’t seated well in the battery clamp.
you can ‘forcefully’ wiggle both positive cables to make sure they are secured in the clamp.
