2003 Discovery 2 Foxwell code reader codes
Old May 13, 2021 | 05:30 PM
Bear774's Avatar
4wd High
Well after many attempts to clean the factory connectors to the positive side of the battery it became apparent that the cable ends were corroded. I replaced with a parts store connector. I was extremely skeptical that this would work. Well to my surprise IT WORKS!!!! I’ve only driven about 20 miles since the repair but still don’t have service engine light on.
Old May 13, 2021 | 05:35 PM
Bear774's Avatar
4wd High
I’m going to keep this thread going and move on to the next issue. I’m not sure how to change the title but I would like to change it to “2003 discovery 2 bringing back to life after sitting for 2 years”. Any help to change the title is appreciated
Old May 13, 2021 | 05:38 PM
Bear774's Avatar
4wd High
The next issue I’m dealing with is with the transmission. I went to take the fill plug out to check the level and the pan was under pressure. As I got the plug loose it sprayed fluid out. Vehicle had sat 2 hours since being driven. I’ve now dropped the pan (didn’t break any bolts!!) and ordered a new gasket and screen. Is the pan being under pressure normal, doesn’t seem normal to me. What would cause it to be under pressure?
Old May 13, 2021 | 10:59 PM
Sandman614's Avatar
@Best4x4 might be able to help
Old May 14, 2021 | 10:33 AM
Dave03S's Avatar
A clogged breather tube would cause that.
Old May 14, 2021 | 10:40 AM
Richard Gallant's Avatar
@Sandman614 re the transmission. The engine has to running when you remove the filler plug. If not the fluid will come out of there in big hurry.
If the engine was running then you need to check the breather, it it likely damaged usually melted shut a some point.
Old May 14, 2021 | 03:40 PM
Bear774's Avatar
4wd High
Thanks so much for the help. Engine was not running. Any help as to where the breather tube would be? I’m assuming out the top of the transmission. I will be home tonight so I will look but any direction is always appreciated.
Old May 14, 2021 | 05:24 PM
@Bear774 breather is on top but your problem is the engine was not running, to check and fill the engine must be running. The process is in the RAVE.
Old May 14, 2021 | 06:53 PM
mollusc's Avatar
Even if the engine is off, the transmission fluid should only flow out rather than burst/spurt/splatter. That's a strong indication that you have a blocked breather, but even so, you need to check/fill the level with the engine running.
Old May 14, 2021 | 10:41 PM
Bear774's Avatar
4wd High
Found the breather. Melted completely closed. Clipped the melted end and secured with zip ties hopefully out of the way. New gasket and screen will be here tomorrow. If I have time I will get everything back in place tomorrow night. Thank you for all the help. Next item on the list is a broken air filter top and rotted hose. Will post pics of the trans service and the intake issues as we progress. Thanks again for all the help.
