2003 Discovery 2 Transfer Case Issue
Old Dec 29, 2016 | 08:50 AM
schmitty's Avatar
6th Gear
Default 2003 Discovery 2 Transfer Case Issue
My 2003 Disco transfer case seems to be jammed? I am unable to move the selector from H to L. I am also getting the light on the dash with the two gears with an X through them. I believe this is the transfer case in neutral light. I checked the interlock solenoid, and it seems to be working properly. What is confusing me is that the truck seems to be stuck in Low range but the lever is indicating High range? Any help would be appreciated!
Schmitty
Old Dec 29, 2016 | 09:04 AM
Red5's Avatar
Originally Posted by schmitty
What is confusing me is that the truck seems to be stuck in Low range but the lever is indicating High range?Schmitty
Sounds like you need to adjust or fix the cable.
Old Dec 29, 2016 | 05:51 PM
Best4x4's Avatar
If the interlock isn't the issue disconnect the cable and manually shift it at the TC. Gears flashing = N
Old Dec 29, 2016 | 06:10 PM
schmitty's Avatar
6th Gear
That's what I would've thought that meant too, but the truck goes into D and R. Just in low range. Although looking at the linkage on the top of the transfer case, it appears to be in High????
law_zon
Oct 9, 2016 03:07 PM
JohnRL
Jun 17, 2010 09:35 AM
gsxrgessler
Feb 15, 2010 09:48 PM
csb
Jul 23, 2009 08:57 AM
Disco Dana
Feb 19, 2009 05:47 PM
