2003 Discovery with CDL?
Old Sep 29, 2013 | 01:43 PM
JayCK74's Avatar
6th Gear
Default 2003 Discovery with CDL?
I have a 2003 Discovery that has, what looks like, CDL. I have not seen another 2003 Discovery with the same transfer case shifter that I have. All of the literature that I have read indicates that this is not possible yet there it is. Has anyone heard of this phenomenon?
Old Sep 29, 2013 | 02:08 PM
turbodave's Avatar
There was someone on one of the other forums that had one that had a CDL and appeared to be factory. You should be surprised at nothing from Lode Lane tbh...
Old Sep 29, 2013 | 02:13 PM
ZGPhoto's Avatar
Just post a photo...
Old Sep 29, 2013 | 02:55 PM
jafir's Avatar
I'm voting you have a 2004 built in 2003. What's the 10th digit of the VIN?
Either that or someone added the CDL. A 2004 or D1 CDL lever looks pretty stock. All of the cutting, if required, would be hidden.
Old Sep 29, 2013 | 03:09 PM
ZGPhoto's Avatar
Or better yet, why don't you slide it left and lock it?
Old Sep 29, 2013 | 03:36 PM
JayCK74's Avatar
6th Gear
The 10th digit of the VIN is 3. I just went in it and verified that it slides over to the left and then the indicator light goes on that the manual says mean's the differential is locked.
Old Sep 29, 2013 | 07:51 PM
ZGPhoto's Avatar
If it moves left at all you have a CDL. Are the roof rails on top 4"+ wide or 1.5" wide?
Old Sep 30, 2013 | 01:01 AM
dwvninety's Avatar
I had an 04 LT230 Transfer Case and 04 Shifter put into my 03 Discovery. Works well, The donor vehicle had 38K. So when I do end up selling it the next owner will have an 03 with CDL.
turbodave
Mar 29, 2019 07:22 AM
BrandonS
Jan 6, 2015 09:30 AM
boxerboy2
May 10, 2011 07:19 PM
lipadj46
Feb 11, 2010 07:45 AM
jycsalas
May 4, 2009 11:43 AM
