2003 Discovery Knocking!!
Old Apr 29, 2012 | 09:12 PM
  #21
vandev's Avatar
Default come on ....
Come on guy's.. I think all senior members should be guilty of not saying it like it is..... The LR motors in the RR, Disco 4.0 and 4.6 NAS are the biggest pieces of f$cking **** know to this planet...For a so called prestigious car company to pin their name on this motor...well they should have been shot... A bunch of f$cking *** clowns...In all the 40 years of car and truck ownership ..This has been the biggest piece of sh$t I have ever owned..
If you plan on owning a Disco ...you should know from the get go it's going to ball up and go in flames... assume that and you will be ok..
Chris
Old Apr 29, 2012 | 09:49 PM
  #22
I don't know, I see plenty of other cars and trucks in the junk yard, lots of Jeeps, some look so nice you wonder why they were scrapped at 170K... lots of things don't do well without routine maintenance. Rover selected an engine from an era when 50,000 miles was the lifetime of a car, people traded in every 2 - 3 years. That same engine was 180F stat in the early 60's, no one back then ran an aluminum head engine over 200F. Enter the pollution control departments, and we have to run at the bleeding edge. Keep boring out the cylinders for more power and torque and the engine "meat" gets thinner, heat problems go up. GM has made plenty of engine designs since then. One was in the Vega....
But high dollar vehicles have prestige, and plenty of couples get one or two to go with that new 4500 square foot home on a culdesac. And they lease the cars. And the stork flies over a couple of times. ARM jumps up to Jupiter. And the corporate ladder climbing owner is soon having to cut back on things. Enter to 25,000 mile oil change. Right before lease turn in. Happens with Mercedes, BMWs, Lexus, Audi, and on and on. We are not alone in the "these expensive cars are a POS" department.
BMW sludge, anyone?
Old Sep 8, 2020 | 09:18 AM
  #23
Keegan Walcott's Avatar
Default Discovery 2 td5
Originally Posted by jzakary
OK! I know everyone is going to remind me that this issue has been discussed a million times before, but nobody seems to have the definitive answer. I’ve heard everything from impending oil pump failure to the metal sleeve around the cylinders are shifting.
I’ve got a 2003 Discovery with 120,000 miles (Not in the oil pump VIN # death range!), and it has developed a metallic knocking sound at idle, only at operating temperature. Extremely loud at times! There are no other signs of engine failure (overheating, tailpipe smoke, consuming oil/coolant). I went to my land rover mechanic and he said that I should just live with it. He said that you can spend thousands of dollars trying to find the source of the knocking. As long as it doesn’t get worse, it should be fine.
I guess my question to you all is, am I living on borrowed time here (Oil Pump failure), or should I just drive like I own a diesel engine??
Thanks!
Josh
Hey mate I have the same issue. No light no high temp.. but when I'm idle when the engine is worm and I turn the AC on I hear a knocking sound.. it maybe be your bearing that sits on the end of the fan. If it's the bearing that's a easy job if your mechanically minded but if it's the housing 😬 very big job need to take all front end off and most of underneath your engine.
Old Sep 8, 2020 | 04:27 PM
  #24
merebel's Avatar
And take a look at this solution write up https://landroverforums.com/forum/ge...ghlight=liners
Wonder at what temperature the ticking begins? 160? 180? 190? 210?
mine starts around 190-195 if at idle or drive thru. If open road no tick really
Old Sep 9, 2020 | 06:04 PM
  #25
Extinct's Avatar
What year model? if pre 2003, get an inline thermostat and a 170 degree thermostat, if 2003 or later get a 180 degree thermostat for the inline. The inline is more reliable and cooler than the factory Disco stats so it will keep it out of the tick range and keep the HG in good shape.
Old Sep 10, 2020 | 09:23 AM
  #26
merebel's Avatar
Mine is an 03 w/secondary air. Normal highway temps are at 188. Not leaking any coolant at all stays at same level and has been flushed also.
i would prefer a 170 thermostat in it myself
Old Sep 10, 2020 | 10:36 AM
  #27
mollusc's Avatar
A 170 thermostat in a 2003 will trip a low temperature alarm. Some of the fuel trim systems also won't go into their regular cycles.
Old Sep 10, 2020 | 10:38 AM
  #28
merebel's Avatar
well that’s a bummer
wkburns
Mar 28, 2014 08:11 PM
Bartlomiej
Sep 17, 2013 06:17 AM
xhogsx87
Dec 5, 2012 03:34 PM
TRIARII
Jul 1, 2012 07:37 PM
wardo
Mar 8, 2010 03:08 PM
