2003 Oil Pump Issue and New Timing Cover Problem?
I don’t know what to do… really bummed with this. I’ll have to see if I missed the return window for the AB part - another $500. It seems the problem is the alignment of the dowel pins (they’re clean and polished) unless both of these covers has holes that are a bit off - the SKP cover was tight on both pins, but especially the upper one. The Eurospare cover slips onto the upper pin almost too easily (up to the point only a few mm are left, then it gets stuck, possibly because of the other pin that almost won’t go in at all). I’d tried hitting the SKP cover hard with a mallet - it seemed like I was putting in an unreasonable amount of effort as one hole in the SKP cover began getting damaged at the chamfer and others said this is supposed to slide right on, which is definitely not the case here. I didn’t try hitting the Eurospare cover that hard, but definitely gave enough force to see that it also wasn’t fitting on easily.
I don’t know what to do. The best option I can think of is to return the AB cover and either buy new dowel pins (not sure how to get the old ones out or the new ones in properly without damaging the block), then try the SKP cover again, and, if it doesn’t fit easily, I could either drill the holes a bit or file the pins.
Please advise… the SKP cover was half the price and has a Corteco seal, the water pump, glow shift pressure sensor/adapter and the sump studs in it already. It’s also already primed with petroleum jelly, so I’d rather use that one at this point.
Feeling pretty lost here and my only ideas as the ones I’ve listed above.
Thanks y’all
Thanks y’all
Maybe the pins are not seated completely into the block, or they are too long?
I would try removing one (carefully twist out with vice grips or channel locks), then try the cover. Or remove both, clean the holes, make pins shorter (or buy shorter pins) if length is the problem. See how the pins fit into the cover while the pins are out.
Last edited by JohnZo; Oct 6, 2022 at 12:02 PM. Reason: loose fit pins into cover test
It seems that the dowel pin holes are slightly off on each cover since one pin went in easily with the Eurospare cover, but the other wasn’t going in at all, which is the opposite pin I struggled with on the SKP cover, although neither simply slid into place.
I’m worried about tearing out part of the block if the pins grab it too tightly and when I’m spinning them out. I saw that AB sells the pins, so I guess others replace them…
