2003 trans warning lights on dash ? Why.
Old Jan 12, 2009 | 10:15 PM
cwdisco's Avatar
3rd Gear
Default 2003 trans warning lights on dash ? Why.
My 2003 disco has 2 warning lights on the dash that blink at the same time. Also I just noticed a small trany leak. The lights are the sport and manuel mode lights. I also learned from this forum that my vin # falls in the bad oil pump range.
Old Jan 12, 2009 | 10:59 PM
AK Rover's Avatar
Default RE: 2003 trans warning lights on dash ? Why.
The S & M lighs blink like that indicating that your battery voltage is low. Could be your battery is bad or your alternator could be bad and not charging the battery properly. Go to an auto parts store and have them test your battery. I bet that your battery needs replaced.
Old Jan 13, 2009 | 11:21 PM
cwdisco's Avatar
3rd Gear
Default Thank you AK Rover.Blinking dash lights.
I think you were dead on about the low battery. I tried to start it up.....completely dead.I have not checked the battery yet. I have a trans question, it just started leaking. Is there a problematic seal or something that will usually go bad? Is there a spot to check first. I'am a great carpenter but a lousy mechanic. Thanks again, Chris.
Old Jan 14, 2009 | 11:54 AM
Default RE: Thank you AK Rover.Blinking dash lights.
You really need to read your owners manual so you know what your truck is all about, all your warning lights are described in detail.
As for your fluid leak, once you read how to check and fill the tranny, you might want to then do it before your toast it.
cipher982
Nov 9, 2019 11:22 AM
filthydisco01
May 22, 2013 01:04 AM
rphotographer
Oct 30, 2012 08:35 AM
Mpowered
May 15, 2007 08:42 AM
XBlade
Feb 26, 2007 10:49 AM
