2004 D2 Restoration
Old Aug 1, 2018 | 11:29 PM
1953andrejrigoli's Avatar
8th Gear
Default 2004 D2 Restoration
Howdy .
​​​​​​Not crazy restoration just very reliable..
Bought 2 spare D-2's.. One an 03 SE-7 for rear seats..
My want is your recommendations regarding wheels/tires.
Mostly on-road (90%) and, I'm still going off-road, not crazy..
I'm in Southwest Arizona
I have stock 18" wheels & I have stock 16" wheels.
I'm told 16" give me more cost-effective tire options.
Yes, I prefer to ride on high & wide tires but, am not lifting it.
New OEM Shocks..
Please advise your experience recommendations?
Much appreciated.
AJ
I'll have plenty spare parts when complete, end of this month.
Old Aug 2, 2018 | 09:39 AM
CollieRover's Avatar
The nicest part of the SE7 is the rear Air conditioner, but maybe that comes in other models, I don't know.
Refresh the entire Cooling System, all hoses, and Thermostat. Make sure the Radiator is flushed out really well and it maintains good temp. That means getting a Scangauge, ultragauge or other OBDII tool to monitor.
Do all Fluids, check all hoses, and look for leaks.
Pull off the top of the intake, do new injectors, coilpacks, plugs and 8mm wires, and give the lower intake manifold a good once over. It would not be a bad idea to do new Crankshaft position sensor, Throttle Position Sensor, but maybe not necessary.
If the Truck has never overheated, and the cooling system is in good shape, and you can monitor temps so that it never does.
I mean, an entire rebuild is a good idea, but it depends on miles, and what has already been done. New water and oil pumps would not hurt either.
JoeLena
Nov 14, 2018 03:24 PM
nickm347
Sep 3, 2017 03:01 PM
badassbmwm3
Aug 22, 2015 07:23 PM
RYAN3326
Jan 15, 2013 01:47 PM
bangkuaidiscovery04
Oct 11, 2009 01:15 AM
