2004 Disco 2 Engine Rebuild
#111
#112
I will tighten the exhaust manifolds and bleed the coolant of air tomorrow and see if it improves.
#113
#114
Warning! Dumb@ss Ahead
Ok so I bled the coolant this morning. There was air in the system. While I was out there I thought I would check the oil level because my drain plug has a slow drip. Turns out my oil level was down 4 quarts (no errors or lights on the dash). Apparently the oil drip is a lot worse than I suspected. I was planning on finishing out the beak in period before fixing the leak but now I am going to get that fixed today. I think I dodged a bullet but I don't like the fact that I let it get so low - especially during the break-in period.
Good news is there was air in the system when I bled it this morning using Disco Mike's method. The bad news is that I am still running between 217-221 during idle and not much better than that under load. Ironically, if I have the AC on full blast while driving on the highway, I can get the temps down to 197. So my question to you all is, what about running the AC full blast is dropping my temperatures on the highway? Why doesn't it help during idle? What's the next place I need to look?
CollieRover indicated I might have some unrelated exhaust leaks due to the engine sounding like a diesel during acceleration (thanks!). I will be tightening the exhaust down as soon as I get the oil leak and temps behind me.
#115
#116
Running your heat on full blast will help with temps not A/C.
If it is getting hot at idle I would guess that your viscous fan clutch is bad and not engaging the fan at idle. Causing low air flow thru the radiator. Try a new clutch and fan, Best has a recommendation for that.
#117
#118
I highly recommend a Ron Francis Controller, mine has dual fan function, but that is not totally necessary. The controller is much more heavy duty than flex a lites, is beefy, has relay and fuse so I feel 100% confident in it. I mounted it next to the BCU on the bracket. Works incredibly well.
I have a thread on my electric fan adventure and temps. The real limiting factor on the cooling system is the bypass design. I had the same temps with a flex a lite fan, Taurus fan, HD viscous clutch fan and my current setup.
cvhyatt (10-08-2019)
#119
Thanks - I am not as "handy" as most on these boards so I would prefer getting a complete kit that I can drop in versus pulling something from another vehicle, fabricating brackets and modifying the shroud. I am in awe of people who can do this kind of thing - I'm just not one of them! Any suggestions on a drop in kit that only requires basic automotive ability?
