2004 Disco 2 Engine Rebuild
#202
Also recompressed my caliper but I am willing to bet I will need to replace it.
I have also been chasing a clank when going slow over speed bumps. I jacked the tires up 2 inches and stuck a pry bar under each. I could see any play or replicate the sound. I did find a potential warn out bushing? See pics below. Seems like a gap on one side but not the other? Not sure what part this is yet.
Recompress the caliper
Drivers side. Big gap. No bushing?
Passenger side. Seems like there is a bushing here.
#203
#204
#205
I am rebuilding my 4.6
Remanufactured heads from a great vendor/member here were $400
Crower cam $250
Finished cam bearings $150
Crank, rod bearings, $75
Oil pump, $40
Lifters and pushrods $120
New timing cover $390
ARP head studs $75
Elring head gaskets $50
All other gaskets and sealants, under $100
Gates waterpump $75
Rings $100
Coil packs, plugs and wires, around $100
Doorman and Gates fan and fan clutch $60
Idler pulleys and tensioner $70
Remanufactured Bosch injectors $80
good used 4.0 block $400
+ oil, coolant, thermostat, freeze plugs, etc, another $100
I'm around $3k in parts and zero for labor as I do the work.
Crower cam $250
Oil pump, $40
ARP head studs $75
Gates waterpump $75
Rings $100
The following 3 users liked this post by Sixpack577:
#207
@RoverSE7 the cost @Sixpack577 figured out is about, what I figured with a used pressure tested block if I had a crack. Since then I found I can order darton top hatted liners and the local machine shop will install if I wanted to go that way. So 600 cdn for liners and about 1500 for install. That is still a lot cheaper than a turner short block.
#209
#210
@Sixpack577 I am pretty sure it is just a head gasket but good to know
I think I would try a torque wrench at 70' lbs on all the head bolts before you take them out.
I'de still do the head gasket job, but just for curiosity.
Since you previously wondered if one had came loose.
It'll only take a minute to hit them all and find out for sure.
