2004 Disco 2 Oil Problem
No it's their but could it be stopping the oil from circulating? What can cause theses units to fail, I suspect the cold because it was around 12 degrees I began to hear the noise.
While the front cover is off, pop the c-clips out of both bypasses and clean them out and carefully reassemble. If you get one of the bypass plungers stuck in the bore when you put it back together, your oil pressure will be sky high when cold.
Finally!!! I got my car back together a couple hours ago after replacing the oil pump gear with a kit from rover parts. When I started my car I still hear the loud tap of the engine. I shut it off and checked the oil and the oil was certainly circulating, I turned it back on and my oil light went off. After letting it run for 5 or so minutes the tap got very quiet and disappeared. My theory is my pump went bad and didn't allow oil to get to the lifters and they dried up and started tapping, after installing the new pump they got oil and started working just fine. Thank you all for your help and keeping another disco on the road to break down another day.
