2004 Disco 2 Oil Problem
Old Feb 23, 2015 | 02:58 PM
dusty1's Avatar
Longish skinny spring? I think you are referring to the bypass relief valve. It operates a piston to help regulate pressure. Do you mean it is not in it's little cylinder?
Old Feb 24, 2015 | 03:18 PM
Disco2Hoonigan's Avatar
No it's their but could it be stopping the oil from circulating? What can cause theses units to fail, I suspect the cold because it was around 12 degrees I began to hear the noise.
Old Feb 24, 2015 | 10:48 PM
Dave03S's Avatar
A cracked oil pump ring would be stopping your oil from circulating properly.
That bypass relief valve can fail too.
The two at once not good.
fix that up and see if maybe you got lucky and didn't toast your engine.
Old Feb 25, 2015 | 06:17 AM
drowssap's Avatar
is not the oil bypass springs job, too bypass the filter if it is blocked. So you would have to have a blocked filter and a bad preasure relief valve at the same time.
Old Feb 25, 2015 | 09:31 AM
5kcstq's Avatar
The oil pump gears are cast and they all seem to break. Mine was in three pieces and yes, they do not pump right when they're in pieces. I had @6psi cold when mine failed... replaced the pump and I sit at a full 20psi hot at 660rpm.
While the front cover is off, pop the c-clips out of both bypasses and clean them out and carefully reassemble. If you get one of the bypass plungers stuck in the bore when you put it back together, your oil pressure will be sky high when cold.
Old Mar 8, 2015 | 08:23 PM
Finally!!! I got my car back together a couple hours ago after replacing the oil pump gear with a kit from rover parts. When I started my car I still hear the loud tap of the engine. I shut it off and checked the oil and the oil was certainly circulating, I turned it back on and my oil light went off. After letting it run for 5 or so minutes the tap got very quiet and disappeared. My theory is my pump went bad and didn't allow oil to get to the lifters and they dried up and started tapping, after installing the new pump they got oil and started working just fine. Thank you all for your help and keeping another disco on the road to break down another day.
Old Mar 9, 2015 | 07:40 AM
drowssap's Avatar
good luck with it
mpwise58
Feb 25, 2014 03:55 PM
DR.DREW2
Jul 17, 2013 11:37 PM
kevinu99
Nov 8, 2011 08:31 PM
ronguiteau
Dec 7, 2010 08:50 AM
airmarc
Dec 9, 2008 12:03 PM
