2004 Disco 2 Stutter around 1500 rpm
Old Apr 30, 2013 | 02:56 PM
resiroper's Avatar
Default 2004 Disco 2 Stutter around 1500 rpm
Hello all,
My Disco 2 starts cold fine and runs warm fine. I do have a new item starting to happen that I could use some help with. At around 1500 rpm it feels like it stutters. Not a back fire and no fault codes. I can power through it fine and it does not seem to be making the vehicle undependable. I have 90K on the unit and it is very well maintained. I want to call it a miss but that would be overselling it. It seems to me that I should start troubleshooting one of the inputs to the engine management system but where to start? I still drive the vehicle every day and it seems to do fine just the stutter. I does not seem to do it under power but only when I am at a level speed say around 30 to 40 and 1500 rpm. Any input or anyone with the same issue I would love to hear what you found. Thanks Scott
Old Apr 30, 2013 | 05:13 PM
Plugs and wires new? Any codes?
Old May 1, 2013 | 06:58 AM
resiroper's Avatar
Savannah, Plugs and wires are new as is the catalytic converters. There are no codes showing. I did borrow a Hawkeye meter from a friend and it showed that there were misfires on cylinders 3 and 5. I will check them this evening to see what they show.
Old May 1, 2013 | 08:50 AM
roverguy7's Avatar
I'd be double checking the wires with the codes.
Will the stumble happen in any gear at the same RPM?
dregill
Aug 5, 2015 07:27 AM
Snafu / Disco Fries
Jan 17, 2012 11:37 PM
mark wilson
Sep 20, 2011 05:54 PM
disc oh no
Aug 5, 2011 04:21 AM
hilltoppersx
Apr 1, 2010 11:33 PM
