2004 Disco
Old May 28, 2018 | 05:33 PM
Don Woodard's Avatar
Default 2004 Disco
Have two I’m looking at, any suggestions as to things to look at?
Old May 28, 2018 | 08:24 PM
Richard Gallant's Avatar
Start here
https://landroverforums.com/forum/di...scovery-21328/
Get a code reader or arrange for the codes to be checked by someone you trust not the owner of truck.
But cooling is a big deal with these as it an aluminium engine. Get a cheap Elm 327 wireless code read and torque lite for your Android phone not sure what to use on an idevice. When you take the truck for a test drive plug the Elm 327 into the ODB port and monitor the temps while you drive at least 20 minutes.
If the owner will not allow you to do so walk away - that is a bad sign.
Have some coveralls and crawl underneath take a look for leaks before and after driving.
Ask for maintenance records when the last oil and coolant service was done - coolant should be annually and oil at least the same or every 6 months.
Check the CDL - both low range and diff lock - you do not have drive far a couple meters will do.
Check every switch, the heat and AC.
Ask point blank about water getting inside sun roofs, windshield, rear door seal. Check for rust yourself - passenger side and drives side seat bolts typically show it up. Check the headliner for sagging, this usually indicates water got inside somewhere.
Check the belt for tension, rad hoses etc.
Get an image of all the lights on the dash, that come on when turn the key, make sure they all work - there have been issues of lights being removed or taped over.
Lastly listen to the engine when it starts and is running - exhaust leaks and ticking which is what you are listening for.
It likely has secondary air - right side big back cylinder near the fire wall - it should make noise when the truck starts only briefly though
Old May 28, 2018 | 09:24 PM
No Doubt's Avatar
The ELM327 is cheap and a good idea above. Do that. Check your coolant temp with it while driving and check the error codes. Clear the codes. Drive more and see which codes return. Most error codes are trivial emissions-related. While driving, your app for the ELM327 will tell you if you are in closed loop or open loop mode. Closed loop is good.
If coolant temps never go over 207F no matter what you do, you are on track for a winner.
Don't overthink things. All British cars leak so don't freak out underneath. What you really want to see underneath the Rover is if it has rust or damage-repair welding.
What you really want to see is hard to get: whether the coolant level has dropped after driving and the engine has cooled off later. You can sort of get this if you see huge amounts of white smoke coming out of the exhaust (bad) or a steady stream of coolant/water flowing out of the tailpipe (typically bad, often a blown head gasket).
You know, test the brakes slow and then fast. Is A/C cold? Power steering works? Cruise control works?
These are old trucks. Don't set your expectations for a factory new vehicle.
You do want to know if the motor "ticks" loudly when idling. You do want to look at the color of the oil (black/sludgy is bad).
If price has good value vs condition and the title is clean, go for it!
Old May 28, 2018 | 09:32 PM
Saturnine's Avatar
Search the forum, there are a bunch of threads about this topic
Old May 29, 2018 | 06:02 AM
Thanks, I have two in my search, one with a , said exhaust manifold crack, but lots of new work, the other, bit more cost, but maintained by a reputable known shop, all records and books. To me, books on euro cars are a must.
Will take your advice and look. Thank you all very much.
Old May 29, 2018 | 06:06 AM
shanechevelle's Avatar
What kind of do it yourselfer are you?
Old May 29, 2018 | 06:55 AM
CollieRover's Avatar
The rub on these trucks is that the original engines have a cylinder sleeve slipping issue. This makes an original engine a negative, working or not.
It would be preferable to buy one that is not running, and put in a tophatted engine block or do an LS swap. Of course, this changes the cost a ton, but you get a much more reliable truck.
of course, you may find one that already has a Turner or other tophatted engine in it.
Immediately install an obdII tool that will show you temps, and take care of your cooling system as if it were your life.
Old May 29, 2018 | 07:00 AM
I’ve built several engines, rebuilt a 911 once, Mercedes, several American cars, hot rods too. Do I want to again, prefer not, but anything is possible
Old May 29, 2018 | 07:15 AM
If the cooling system has been maintained well, the cylinder sleeves may be ok. But make sure you get a truck to operating temps in both highway and congested situations to watch the temps with an obdII tool. The dash temp sensor reads 220 as in the middle, so the truck may operate well outside of normal temps for long periods of time. So these knocking issues can come and go.
If an engine rebuild is within your skill set then an original engine would be an acceptable risk as you’d avoid labor of an engine swap etc.
Old May 29, 2018 | 07:23 AM
I have an SE7, and while I find the jump seats sort of in the way for golf clubs etc. that model comes with a really nice A/C system for the rear.Maybe they all do I don’t know, but it is nice to have.
Look at the ABS wires and see if the original connectors are being used, or if they have bypassed them and soldered into the wire near the Computer. The original connector is preferable, as changing the pins in the connector is next to impossible, and sensors are plentiful and cheap that amintain the original plug.
