2004 disco towing capcity
Old Aug 5, 2008 | 02:26 AM
Urban Panzer's Avatar
Default RE: 2004 disco towing capcity
ORIGINAL: Spike555
UP-Its because you drive on the wrong side of the road. The left side of the road can hold more weight.
Power is not an issue, I towed my D1 home on a trailer for 125 miles in HIGH range at up to 60 mph in my Td5with no issues at all !!!
to be blunt about it, imo thatlow range sh*tin the US manual imois a load of bo^^^ox!!!
Old Aug 5, 2008 | 02:29 AM
And I would not advise using a particular gear, if its an auto use D, if its a manual drive it as you normally would, using only 1 gear will put strain on the tow vehicle when theres no need
Old Aug 5, 2008 | 05:22 PM
But by running it in 3rd instead of 4th gear he will keep the trasmission from shifting into 3rd everytime he comes to a incline thus keeping the trans from overheating.
And remember Nick, you have a diesel, we have petrol, you have more tourqe.
Old Aug 6, 2008 | 02:05 AM
I see your point spike, so it would be best to start in 1 and change up to 3rd once moving, if you prefer it that way. As far as torque goes buddy, the TD5 is "about" the same asthe 4.0 V8
Old Aug 6, 2008 | 01:13 PM
Also by keeping it in 3rd you have engine braking and you keep the RPM's in the HP range so it pulls better. Just put it in 3rd and go.
I would have thought that the diesel would have more tourqe than the V8. Even with a small displacement.
Old Aug 7, 2008 | 04:33 PM
gruehle's Avatar
6th Gear
how about weight distribution systems? we are looking at 4100 to 5000 lbs and 25-29 ft.
Old Aug 7, 2008 | 04:35 PM
Dont bother. You are still pulling 5,000lbs. You will be fine.
Old Aug 7, 2008 | 04:36 PM
The frame isint the weak point, its the axles/transmission. But you'll be fine.
grandkodiak
Nov 25, 2013 08:05 PM
NWDiscoRover2004
Mar 11, 2010 10:53 AM
bradb
Jul 8, 2007 08:28 AM
boyofcows2
Feb 18, 2007 04:16 PM
Benhamtroll
Jul 22, 2005 12:31 AM
