2004 Disco Wiper Issue
Old Oct 23, 2013 | 10:06 PM
mtnduc's Avatar
Default 2004 Disco Wiper Issue
New owner.
100K+ on the beast
Wipers sorta work most/some of the time, however when the temp drops they don't work at all.
Bad relay, motor ?????
TIA.
Old Oct 24, 2013 | 11:50 AM
kman3786's Avatar
Sounds like bad motor. There's switches in the motor that wear out. Replaced with new motor and all was fixed.
Old Oct 24, 2013 | 01:59 PM
SuperSport's Avatar
The switch on the Stalk has grease inside that when wearing out will get hard in cold weather. You can clean and replace that grease, then all will be well in Rainy Weather.
https://landroverforums.com/forum/di...tch-fix-46886/
Old Oct 25, 2013 | 09:59 AM
mtnduc's Avatar
Thanks.
I don't think it's the switch.
The blades move kind of erractically or not at all.
I think the motor is the culprit.
Old Oct 25, 2013 | 10:59 AM
SuperSport's Avatar
Originally Posted by mtnduc
Thanks.
Still sounds like the switch to me. Mine has done it in cold weather. Does not work at all, or erratic. Warm weather, it's fine.
PPK Zombie
Oct 18, 2014 05:20 PM
bcolins
Feb 2, 2014 09:40 PM
tbesselman
Feb 2, 2010 06:52 PM
millejdq
Dec 6, 2007 12:23 PM
SpeedAgent
Oct 10, 2007 09:28 AM
