2004 disco2 oil pump
Old Apr 27, 2020 | 09:27 PM
231john's Avatar
5th Gear
Default 2004 disco2 oil pump
I'm replacing the oil pump. my question has to do with the center gear ( with the keyways, that rides on the crank shaft). if you slide it back it sits flush with the center sprocket but sliding it forward it sticks out a bit, not flush. when assembling this piece does the flush end face the rubber seal ( towards radiator) or does it face the oil pump cover plate ( towards engine block)?
this pic shows the keyed sprocket pushed back and it's not flush. its flush when pushed to the other end.
boris_gti
Oct 12, 2011 11:47 AM
shonuff93
Feb 20, 2010 10:23 PM
Cessna310Guy
Nov 24, 2008 06:39 AM
Disco C
Oct 23, 2008 06:39 PM
shagybruce
Feb 20, 2007 07:11 PM
