2004 discodoor lock actuator
Old Oct 12, 2008 | 02:51 PM
wesley64's Avatar
Default 2004 discodoor lock actuator
i have the rave manual.my question is;can you remove the latch/actuator without femoving the door/glass frame.any short cuts?
thanks
brett
Old Oct 12, 2008 | 03:04 PM
Default RE: 2004 discodoor lock actuator
I dont know about a DII, but on a DI you can. Just remove the inside door panel and roll the window up.
Old Oct 12, 2008 | 07:39 PM
Darover's Avatar
No you can't. Just follow along like the rave cd says. I've done all five and although it can look and sound a bit extensive, like on the front one where you have to remove the side mirrors and all, but it really is pretty easy if you follow the instructions. The only bitch I found, was the rear window frames that can be a pain to remove.
Old Oct 12, 2008 | 10:59 PM
wesley64's Avatar
thanks.i figured as much.i have to order the parts anyway.i am not in a real panic to repair them anyway.
brett
Old Oct 13, 2008 | 05:30 PM
Darover's Avatar
well, if you ever need assitance while facing a problem with the removal and/or installation of the actuators that is not covered by the rave cd, just let me know and I might be of some help.
Brad S1
Jan 23, 2018 09:02 AM
motormikeyman
May 1, 2008 03:39 PM
Spike555
Apr 14, 2008 08:13 AM
marshman 442
Jan 13, 2008 10:15 AM
Brad S1
Dec 5, 2006 05:29 AM
