2004 Discovery 2 CDL
Hello,
Was just wondering how I can get a CDL on my 2004 Disco 22 as it does not have the factory one (pursuit model) should have held on for a HSE but the car is also used for work and I couldn't waste even more time getting a good HSE. This pursuit I got is brill and basic but lacks CDL. This is not a major concern at the minute but I would like to know for the future what the best way of getting a CDL on the '04 Disco is. I don't know if the spigot is there as was on the pre-facelifts.
Thanks in advance,
Mike
Thanks in advance,
Mike
You need to confirm you don't have the nipple (you can crawl under the truck and reach on-top of the front of the transfer case (right behind the front drive shaft) and feel for it...I am not 100% sure on the 04)...if you don't here is all the info you need...buy a used transfer case NOSE assembly from any used rover parts guy (Paul Grant is a good source...contact info in discoMike's signature)
2003CDLInstall - LAND ROVER CLUB V.I.
If you have the nipple all you need is the linkage...below is one route...another is to get a linkage out a D1.
04 CDL Shifter Installation Video - Land Rover Forums : Land Rover and Range Rover Forum
This is one of the most detailed topics on the forums. Use the search function and you will find more than enough info.
You need to confirm you don't have the nipple...if you don't here is all the info you need...buy a used transfer case NOSE assembly from any used rover parts guy (Paul Grant is a good source...contact info in discoMike's signature)
Cheers
You need chek and see if the transfer case has the CDL nipple first. If not you need to either swap the front output housing with a t-case that does have one or swap out the whole unit. Then you need to decide if you want the standard 2004 air shifter for the CDL lock or if you want a Discovery 1 mechanical shifter linkage to engage the CDL.
Cheers everyone so far by the way.
did you try engaging from side to side? maybe someone switched the boot. i never heard of an 04 without CDL but you're across the pond and you invented these pieces of crap so anything is possible. like everyone else said get under it and check to see if the linkage is hooked up if not if there is a nipple on the top of the TC. here is what the nipple looks like without the linkage.
