2004 Discovery : Service Engine Soon Light
My 2004 discovery (62k) is having a re-occuring service engine soon light (solid, not blinking), the orginal fault code was for a LARGE EVAP LEAK, the deler told me that they used the T4 scan tool and verified a DTC#-P0455 Large Leak Detected-----the dealership tech tested the system and couldn't find any problem or leak, the system was reset, the vechile pased a road test,......fast forward 2 weeks and the service engine light is back.
the vechile is preforming fine and i am trying to avoid going back to the delareship without some more insight into this issue.....the dealership charges $120 just for an oil change
they talked about doing a smoke test if the fault occured again (sounds expensive)
Any thoughts on what this could be ?
thanks
thanks
Just to add up, you should also check your overall engine performance. You should check every part of the engine especially the Rocker Arm Stud Girdle because it helps your engine power to have a good performance.
on
rinmud
10-01-2005 04:32 PM
