2004 Discovery transfer case leak
Old Jul 29, 2017 | 10:36 PM
bhowell450@gmail.com's Avatar
7th Gear
Default 2004 Discovery transfer case leak
2004 Discovery transfer case leak. The leak seems to be coming from a spot on the transfer case that is copper in color about the size of a nickel in between the transmission and the transfer case. I crawled under the disco just after driving it to determine the location of the leak. I notice that around the spot I mentioned it was bubbling out around the edges and then the oil would working its way down the cross beam. Does anyone know how to stop it from leaking and why its leaking there? I will try to get a picture of the spot tomorrow.
It leaves a pretty good spot on the driveway after driving for a while.
Thanks from drippy
Old Jul 30, 2017 | 01:44 AM
DiscoCam's Avatar
Thanks from drippy
Change the oil in it and add a half bottle of Blue Devil Oil Stop Leak. I've used it on two LT230 transfer cases and it stopped the leaking on both. Worth a shot before pulling the transfer case out and doing a re-seal.
thecarfarm
Nov 30, 2012 10:14 AM
shawnjkelley
Feb 1, 2012 10:24 AM
smokinwheels
Dec 28, 2010 09:09 PM
yonniecarrizo
Dec 30, 2008 06:06 PM
DerrickInMississippi
Jan 12, 2008 07:49 AM
