2004 oil separator removal
Old Oct 12, 2013 | 05:47 PM
eedisco's Avatar
Default 2004 oil separator removal
It looks like the 2003 and 2004 Disco's have an oil separator in the fitting for the breather hose but how does it come out? I pulled the hose off and all I can see is the metal pipe coming up from the v/c is closed at the top with just a small hole in the center. Does the v/c have to come off?......
Old Oct 12, 2013 | 06:59 PM
NiteTrain's Avatar
what does the RAVE manual say?
Old Oct 12, 2013 | 08:07 PM
eedisco's Avatar
I have looked through it but all I found is a layout of the crankcase ventilation system
but nothing on removing it.
Old Oct 12, 2013 | 08:11 PM
NiteTrain's Avatar
post a pic. Most of us on here have the 4.0L not the 4.6L.
Old Oct 12, 2013 | 08:58 PM
eedisco's Avatar
Here is a pic
Old Oct 14, 2013 | 08:19 AM
borchera's Avatar
The metal sleeve pulls out of the valve cover. Within the metal sleeve is the plastic oil separator. Mind the direction the plastic separator goes back into the metal sleeve.
2003 Discover 134K
Old Oct 14, 2013 | 08:34 AM
Why do you want to remove it? If plugged spray carb cleaner down the pipe a couple of times and that normally fixes it.
eedisco
Dec 31, 2015 09:27 AM
austinlandroverbill
Aug 23, 2015 01:03 PM
dougn
Dec 29, 2012 09:56 AM
discoklein
Feb 5, 2011 06:08 PM
discoboy
Feb 11, 2009 01:42 PM
