3 Amigos after hub repair
Old Jul 10, 2020 | 03:14 PM
jmac's Avatar
Default 3 Amigos after hub repair
Before I began my hub assembly repair work on the driver side front, my truck had no warning lights on the dash. After I completed the hub replacement, I have the 3 amigos + parking brake light on dash. It was a very smooth hub fix with no issues. Truck is running great. The truck was throwing a shuttle valve error code before the hub work with no lights on dash. Still throwing the code after hub work. Recently had all the ABS sensors replaced. Any thoughts would be much appreciated!
Old Jul 10, 2020 | 05:03 PM
The Deputy's Avatar
What codes are you getting now? Besides shuttle valve code you were already getting.
Old Jul 11, 2020 | 08:17 AM
jmac's Avatar
Now I’m getting 0440 front left sensor output low and 0840 left sensor signal erratic.
Old Jul 11, 2020 | 04:50 PM
jmac's Avatar
Well, lesson learned. I realized I never cleared any codes after the hub work. I cleared all existing ABS codes and drove around for a bit. Tested again and 3 amigos are no mas!
Old Jul 12, 2020 | 04:33 AM
mln01's Avatar
Glad to hear your good news. But for posterity's sake, very often the cause of ABS sensor codes is the connector between the sensor and the wiring harness.
Best4x4 likes to cut out the connector entirely and replace it with 3M-style heat shrink butt connectors. I've had good luck pulling the connector apart and using needle nose pliers to slightly crimp the recesses on the female side to improve the connection. For others with sensor codes I'd try that first, and if that doesn't work splice the wires with butt connectors.
usaf_disco
May 11, 2017 08:29 PM
Timothy Wright
Sep 27, 2012 10:10 AM
Disco_Fever
Mar 3, 2011 11:38 AM
Torancis_LR
Apr 13, 2010 07:44 PM
ajh
Nov 21, 2007 12:33 AM
