3 Amigos but T/C Still Works?
So I saw a little glimmer of light coming out of the ABS light and took the instrument cluster apart.
Found this hot mess... rtv over the lights
Wierd thing is, I went offroading yesterday since it's fairly flat where we go. I decided against better wisdom to push it and went up a few 45 degree loose sand inclines and when the tires would start spinning I could feel the TC working pulsing the brakes about. My buddy said multiple times that day he saw it working... I've also felt the ABS kick on before in it and I'm assuming with the RTV like this, the lights have been on since I've owned it (about a month).
I just think it's wierd because I read on here if they are on, TC is dead. I'm thinking this isn't true. The only time I seemed to get stuck was when I was teetering on two opposite tires. I could feel it lurching, but never grabbed.
I had a similar problem with my 3 amigos lights coming on and I still pushed my Disco off road, the TC and ABS still worked perfectly fine. The HDC wouldn't engage but I rarely ever used it other than to see if it still works. Fortunately I fixed my 3 amigo issue with new rotors/pads/fluid and I'm still getting ready to put new switches into the module with new seals from Falcon Works.
Point is, with my lights on, most of the system still functioned.
Second2None
12-06-2010 05:26 PM
VikingDiesel
05-22-2009 07:34 PM
