3 Amigos but T/C Still Works?
Old Jun 24, 2012 | 04:30 PM
BrandonS's Avatar
Default 3 Amigos but T/C Still Works?
So I saw a little glimmer of light coming out of the ABS light and took the instrument cluster apart.
Found this hot mess... rtv over the lights
Wierd thing is, I went offroading yesterday since it's fairly flat where we go. I decided against better wisdom to push it and went up a few 45 degree loose sand inclines and when the tires would start spinning I could feel the TC working pulsing the brakes about. My buddy said multiple times that day he saw it working... I've also felt the ABS kick on before in it and I'm assuming with the RTV like this, the lights have been on since I've owned it (about a month).
I just think it's wierd because I read on here if they are on, TC is dead. I'm thinking this isn't true. The only time I seemed to get stuck was when I was teetering on two opposite tires. I could feel it lurching, but never grabbed.
Old Jun 24, 2012 | 05:44 PM
Do you have any warning or check engine lights on, if so what are the fault code numbers?
Old Jun 24, 2012 | 05:58 PM
Bkreutz's Avatar
I've seen the "black tape" over the light trick, but filling up the hole with RTV is a new "fix" to me. Kinda reminds me of the repair of a fiber optic line with a butt connector I saw once (hi grade stereo install)
Old Jun 24, 2012 | 10:29 PM
FlyingZebra34's Avatar
I had a similar problem with my 3 amigos lights coming on and I still pushed my Disco off road, the TC and ABS still worked perfectly fine. The HDC wouldn't engage but I rarely ever used it other than to see if it still works. Fortunately I fixed my 3 amigo issue with new rotors/pads/fluid and I'm still getting ready to put new switches into the module with new seals from Falcon Works.
Point is, with my lights on, most of the system still functioned.
Old Jun 25, 2012 | 02:27 PM
BrandonS's Avatar
The only OBDII code I get related to the ABS/TC system is the standard 1592.
ytoddmalibu
Feb 3, 2015 06:15 AM
mln01
Jun 6, 2014 11:41 AM
VikingDiesel
May 22, 2009 07:34 PM
VikingDiesel
Mar 11, 2009 07:20 PM
