3 Amigos induced by a bump
Old Oct 30, 2012 | 11:24 AM
bink1109's Avatar
Default 3 Amigos induced by a bump
Check this out...I pulles into a carwash and as soon as my front left tire hit the ramp-stop the 3 Amigos showed up??? Does this tell me anything imparticular or does it not tie in at all? Thanks in advance for the thoughts.
Also, is it true that when the 3 amigos are turned on that the disco will struggle offroad?
Old Oct 30, 2012 | 03:37 PM
Spencerfitch's Avatar
?? No.
They have gone off since right?
It just meant you had a wheel slip.
Old Oct 30, 2012 | 03:45 PM
jafir's Avatar
It could indicate a loose solder joint on the board that the SVS plugs into.
With the lights on off road performance will suffer, especially without a cdl.
Old Oct 30, 2012 | 04:12 PM
As long as they stay off, you are OK. If they go over when wheeling, yes you will loose the ETC, ABS and Hill Decent.
Old Oct 31, 2012 | 02:21 AM
bink1109's Avatar
Thanks for the replies. The lights went off after I recycled power. It has been an intermittent problem, I am in the middle east and cannot find anyone who has the abs scanner. I do not want to tear into it without some decent direction. I also do not want the amigos to show up when I am 20 miles deep into the dunes! Unless losing those features is not that big of a deal in the sand...if that is the case, the amigos can hang out with me whenever they want...lol
Old Nov 18, 2012 | 09:34 AM
bink1109's Avatar
Update...
I continued to have 3 amigos come and go until last week after a dune trip. I deflated, cruised for a couple hours, reinflated and have not seen them sinse. Is it possible that my tire pressure was not the same all the way around, and a sensor was getting bad info and in turn kicking out the 3 amigos?
CANAMDiscovery
Apr 2, 2012 04:20 PM
brandon4589
Jan 2, 2009 09:47 PM
barnwell
Sep 21, 2007 08:20 AM
thawk78
Aug 18, 2007 12:44 PM
skrams
Mar 28, 2007 11:16 AM
