3 Amigos may disappear?
Old Nov 30, 2012 | 07:51 AM
No body's Avatar
Cool 3 Amigos may disappear?
I made the bypass on SVS (option B) such as described in manual, then made ​​the diagnostic and deleting of the fault codes and resulted that the codes displayed before the diagnostic have been deleted, but appeared a new error with the front right ABS sensor, if I do the replacement of this sensor
could disappear the 3 Amigos?
Old Nov 30, 2012 | 09:20 AM
hilltoppersx's Avatar
do the 3 lights come on right when you start the truck or does it take a minute after your driving? if they come on right away then just replace the sensor. if it takes a minute it could be the bearings in the hub are shot and its wobbling pulling the sensor in and out of range.
Old Nov 30, 2012 | 01:48 PM
No body's Avatar
the 3 lights "come" when I do a few (400-500)meters,
even they are not appearing, but when I made a strong braking and they appear again.
I made ​​the diagnose during the moving car, and and this sensor (the front right) read the values ​​smaller than 3 others. I'm confused I do not know what to do.
Old Nov 30, 2012 | 02:32 PM
check the plug for corrosion before you replace anything. baking soda and water then clean it with electronic cleaner.
cammyr01
Jan 5, 2015 02:42 AM
stanigu
Apr 13, 2010 09:35 AM
iplayblues4u@comcast.net
Jan 6, 2010 08:43 AM
Manhattan
Jul 10, 2006 10:44 PM
