3 Amigos Option B - Help Needed
Old Jul 12, 2023 | 06:24 AM
  #41
mollusc's Avatar
Non-replaceable means that there are components built into the driver's side fusebox that cannot be replaced separately. If they fail or start to misbehave, you have to replace the entire fusebox.
Old Jul 12, 2023 | 06:21 PM
  #42
PNW_disco2's Avatar
Ok, got it. Do you know if I could use the fuse box from a 2006 Land Rover lr3? I have a vehicle that I could pull parts from...
Old Jul 12, 2023 | 06:48 PM
  #43
mollusc's Avatar
Highly unlikely.
Old Jul 13, 2023 | 03:47 PM
  #44
Dweeb Discovery's Avatar
I would just replace the shuttle valve if you have any reason to suspect it is physically bad... it's cheap.
FWIW, no one on here is replacing shuttle valves unless they replace the entire modulator. It's the shuttle valve switches that sometimes need to be replaced.
Old Jul 30, 2023 | 02:02 AM
  #45
PNW_disco2's Avatar
In happy news.... I replaced the shuttle valve switches and the 3 amigos are no mas Thanks all for the help, really appreciate it
Old Jul 30, 2023 | 02:21 AM
  #46
PNW_disco2's Avatar
Hi @nashvegas quick q .... before I haul off and buy a new fusebox... what other indicators might I look for that this is the culprit/issue? Would I remove and look for water damage/corrosion? I've been having some weird electrical issues where all windows will periodically start/stop working, same with the lights on the gear box...
Old Jul 30, 2023 | 02:06 PM
  #47
mln01's Avatar
Uh, I'm lost here. What faults are you trying to address if the Boys from South of the Border are no mas?
Old Aug 1, 2023 | 01:21 AM
  #48
nashvegas's Avatar
You'll want to flip down the cover under the steering wheel -- and really look carefully at the grey fuse box. Look along the edges, or bottom. If you see any weird traces of water stains or corrosion (white traces indicating water, or even green or brown), then remove it and evaluate more closely,
On a D2 I had to replace fusebox most recently, all looked fine with exception of the floors were surface rusted underneath the carpets, and the seat mount bolts/brackets were oddly rusted. Until I removed the fusebox, then I realized it was completely corroded inside and on the back. This car had a history of getting water inside but by no means was it moldy or had wet carpets. It's fiddly and a pain to remove and undo/redo the connectors on the fusebox, but worth it to evaluate.. esp on a D2 that you know had water ingress issues from up above.
FYI: I'd say 40-50%+ of D2 fuseboxes I see in pick n pull yards in the pac nw here are corroded or show signs of water traces on the grey casing -- and I do not pull them for spares.
So I'm not sure if it's your issue .. but it's highly suspect as a potential cause if you know water has gotten inside the front floor/dash.
H Hill
Oct 19, 2021 08:51 PM
landrover discovery 2 td5 2001
Jul 1, 2021 05:04 PM
Anthony Brancato
May 12, 2021 07:57 AM
DiscoNickBK
Oct 1, 2018 07:27 AM
Bulax99
Jun 3, 2018 09:52 PM
